Air to Hydraulic Brakes
Rebelpride
Thomasville, NC
Was sitting on the porcelain thinking chair today and wondered if you could take the deuce brake system and make it all hydraulic, that way there would be no brake failure from lack of air. What purpose does the air serve?
jwaller
19
Columbia, SC
the air is a booster just like a vacuum booster on a car. if you had arnold swartzeneggers leg then you might could do that.
1,127
As jwaller said, the air is just a boost. You'd be well served to spend your time trying to come up with a reasonably priced dual circuit brake upgrade.............
That would be far more useful and if it were cheap enough, you might even make a little spare cash selling the kit to fellow enthusiasts.
russ81
cambridge, ohio
Ok, I'm new to working on big trucks, so do beat me up for being stupid here!
Why couldn't you take the vaccume assist hyd. brake booster/master cylinder/pedal assembly off of say a 1 ton truck, and put it on a deuce? It would eliminate the air system, make your brakes completely hydraulic, and all you would have to hook up is a vaccume line.
Dieselsmoke
CA/NV
diesels don't make much vacuum. Why get rid of the airpack? When properly maintained, they aren't much trouble at all.
Stretch44875
Super Jr. Moderator
30
Tiro, Ohio
Spicergear modified his deuce with a hydroboost(hydraulic, uses power steering pump) system off a newer large truck. Said it works well.
49willys
Las Vegas/nevada
Air Brakes...
Brakes from a one ton truck?
Uh, because that truck is alot heaviertham a one ton truck.
Do have to release a parking brake valve to set the parking brake?
Tom....
1,127
RE: Air Brakes...
The deuce system is a very good system and requires little maintenance. I think you'd be hard pressed to find a system that performs this well for as little money and maintenance.
The little maintenance that it requires is important, though.
russ81
cambridge, ohio
Re: Air Brakes...
Tom....
I've bobbed my deuce so it's not a lot heavier.
rmgill
14
Decatur, Ga
Re: RE: Re: Air Brakes...
49willys said:
ah..sorry not familiar with term bobbed.
I know you'll come up with soemthing,
Good luck,
Tom :)
Bobbed as in shortened.
Bobcat, bobtailed, bobbed hair.
m16ty
211
Dickson,TN
A LDT-465 doesn't make any vacuum at all. It will have positive manifold pressure because of the trubo.
Dieselsmoke
CA/NV
Disconnect the hose from the air cleaner, stick your hand over it, let me know what happens. There WILL be vacuum on the intake side of the turbo.
cranetruck
75
Meadows of Dan, Virginia
Re: Air Brakes...
Tom....
From the info I have, a bobbed deuce is still close to 11,000 lb....empty...
m16ty
211
Dickson,TN
Yes there is if you cause a restriction with your hand. If you have very much vacuum at all with everything in place you better clean your air filter.
