- 413
- 69
- 28
- Brookings, SD
Forum,
I have the following battery setup on my M923:
and am upgrading from this stock 60 amp alternator:
to this alternator that is 260 amps at 28v and 140 amps at 14v:
The reason being is that I have added an A/C kit for a M915A2 that is 14/28v, an Eyecon light system, and other electrical stuff. The wires from the alternator upgrade have to go straight to the battery banks.
I have all my mounts, wire sizes and fuses figured out. My question is this: if I'm reading the wiring diagram correctly, I can delete wire 5 from the stock alternator to the Protective Control Box (PCB) and the stock starter system that includes the PCB will function as intended; true or false? I've ran the "simulations" on P2P and it appears so. However, all you are much more clever than me and P2P, so I'm throwing this out to you for comment.
Sorry if this belongs under the 5 ton modifications forum. Perhaps a moderator can move it if this is a violation.
Thank you,
Al Jones
Brookings, SD
PS, BTW, I've been meaning to post how the Eyecon mounted on my M923, here are a few pics; I'll post the complete install thread at a later date:
Thank you,
Al Jones
Brookings, SD
