Another one saved...
MilitaryRestoration
Vancouver/Yakima, Wa
Had a great trip really... However did have two problems. First one was noticeable right away but didn't find it till we started doing our pre-trip inspection, lubrication, etc. As I was grease'n the drive lines i grabbed the main one going back to the first set of rear axles and it was all sloppy. First thought was o' no...! Universal joint... But come to find out they had just forgot to put the four nuts back on the flange...So off the the local hardware store we went. Got everything prep'd and ready to go and about a 1/4 way of our long journey... Ft. Lewis to Yakima, Wa... the trailer brakes lock'd up for no reason. So after trying to let them cool and get them broke free, with no luck, as well as backing the brakes off (or attempting to anyway) we finally decided to just crack open the brake lines and IT WORKED!... So then we were back on the road again. Truck drove like a dream, but should with new radiator, motor, transmission, xfer case, axles, brakes, winch, driver seat, all new grade 8 bolts everywhere etc etc... Guess my dad saw something I didn't because I did not notice most of what he did when biddin'. A+ dad ;-)
bulldog_mack13
3/3 ACR
2,968
34
Colo Springs, CO
First thought , NICE TRUCK man , Second thought , wow gas is high there .50 cent per gallon less here lol
P.S. I had alot of M105 brake problems before and did the same thing and it worked too
1,808
Very nice truck and trailer. Usually the relay valve is the problem on the trailer brakes. Draining the air out of the tank on the trailer will also release the brakes. It may have a relay valve clogged with some dirt.
MilitaryRestoration
Thanks all for comments... and if anyone needs tires dont forget i've got 50 - 52'2 ;-) with hemmt ring lock rims
Kenny - this trailer does not have a tank on the brake system...that was the first thing i looked for... i found that when i realized that there was only one air hose... service only... never seen this system before...anyone seen it themselves? i'll try to take pictures today
