what page?The manual does have a chart for degrees of change per shim. I think I found a typo in the TM. The amount of change on the rear wheel is the same for both shim thicknesses. The front wheel has a difference of .2 degrees between shims. This is if add/remove the same shims for both buckets of the same upper a-arm.
There is a section in the front titled, "How To Use This Manual"....what page?
Nice!Got started on removing the rear shims today actually. Was surprised how clean they were along with the bolts. Must have been done during the 2014 overhaul. Same number of shims on both ends of the A arm. Therefore having both equal with no shims against the frame should be fine. At the end of the day you can’t make the camber any worse on the backs of these trucks unless you’re hauling a lot of lead or bricks.
did you have to jack up the bottom swing arm to release the top?Got started on removing the rear shims today actually. Was surprised how clean they were along with the bolts. Must have been done during the 2014 overhaul. Same number of shims on both ends of the A arm. Therefore having both equal with no shims against the frame should be fine. At the end of the day you can’t make the camber any worse on the backs of these trucks unless you’re hauling a lot of lead or bricks.
I have jack stands under the center crossmember and got the wheels off. Undo the large bolts on the upper swing arm. Leave the nuts on and hit them with a hammer go get them freed some. I was able to lift up and down on the hub while jiggling the bolts and they came out.did you have to jack up the bottom swing arm to release the top?
when the wheel is off, is there any significant tension on the top swing arm?
the bolts holding the rear cups sure are not easy to get at.I have jack stands under the center crossmember and got the wheels off. Undo the large bolts on the upper swing arm. Leave the nuts on and hit them with a hammer go get them freed some. I was able to lift up and down on the hub while jiggling the bolts and they came out.
I decided to paint what I could on the suspension while it was off and haven’t had someone to help me reattach the upper swing arm mounts. I got tired of holding the impact and the nut on the other side and gave up after 4 bolts. But I am putting it back together with no shims then I’ll do a basic tape measure alignment for the toe.
did you get it back together? how is it without shims? was your camber the same on both sides?I have jack stands under the center crossmember and got the wheels off. Undo the large bolts on the upper swing arm. Leave the nuts on and hit them with a hammer go get them freed some. I was able to lift up and down on the hub while jiggling the bolts and they came out.
I finally got it back together today. Camber looks spot on to me without any shims. There was tons of toe out at first after bolting it all back together. I probably said every cuss word in my vocabulary a dozen times while trying to get the radius arms to move. Finally got them to turn with a 24 inch pipe wrench and a floor jack to get it about 1/6 turn at a time. After a rotation or two I could barely do it with all my weight on it. I did the alignment per the military spec with 1/2" toe out. I also checked against the frame rails to make sure they were even and it wouldn't crab walk down the road. Flash offroad has a PDF of one of the cartoon TMs that shows the alignment specs and procedures. It's on their page for H1 alignment.did you get it back together? how is it without shims? was your camber the same on both sides?
ill probably have mine back together tomorrow. as predicted I only had one plate per bucket, no shims as you can see in the photos i just posted. i’m guessing mine is still going to be high but hopefully much more balanced with the other side.
camber lookin good.I finally got it back together today. Camber looks spot on to me without any shims. There was tons of toe out at first after bolting it all back together. I probably said every cuss word in my vocabulary a dozen times while trying to get the radius arms to move. Finally got them to turn with a 24 inch pipe wrench and a floor jack to get it about 1/6 turn at a time. After a rotation or two I could barely do it with all my weight on it. I did the alignment per the military spec with 1/2" toe out. I also checked against the frame rails to make sure they were even and it wouldn't crab walk down the road. Flash offroad has a PDF of one of the cartoon TMs that shows the alignment specs and procedures. It's on their page for H1 alignment.
