Crank Case Breather Smoke
fsearls92
154
International Falls, MN
I picked up a M931 yesterday for a friend of mine. Once I got it jump started and checked all of the fluids and topped them off I noticed smoke coming out of the breather. It is a decent amount of white smoke where you can see it from the cab when you are at a stop. It also blows a little oil out of the tube also. Any thoughts on what this is. My M923 boesn't blow any smoke out of the tube or oil.
indy4x4fab
Banned
1,711
41
indy, indiana
I had a k30 with a 6.2 that had that problem for a bit. the main thing that i found was that the rings and frozen to the piston. I read up more on it and found that this was a common problem with 6.2 s that had sat for a long time, talking 6 years or more with out running, and that simple letting it sit and idea as well as just driving it would free them up from the piston. Now these rings where not stuck it the Cyclades liners but simply to the piston. The blast from the Cyclades firing would freed them up a a day or two of easy driving, and light on the throttle, and I could feel the two Cyclades come right back. Now this is just my two cents, but I say take it out for a light low rpm run and drive it a couple house and see if it gets any worse. If it still doesn't get any better you may have bigger problems like broken rings or a hole in a piston. So start simple and work to more difficult problems.
03silverado
Millersville, MD
Our international 466 at work blows some smoke out of the breather and a little oil I agree with indy4x4fab try running it a while it will either get better or worse
5,017
Probably not broken in yet. I've got the same thing going on with mine after a in frame overhaul. I need to hook up the M105/genset and work it hard.
bearboley
Circleville Ohio
Id say it has a scored piston, scored liner, broke piston something along those lines. If it has enough blowby that it comes up around the hood when you stop its not likely gonna fix itself.
droprat
Las Cruces, NM
Well- i drained the coolant and a total of about 3 gallons came out. Ugh!!!! I knew what to expect next when i drained the motor oil!!!! Sure enough!!!! A gush of coolant made its way out first then oil.
Well its off to the shop tomorrow to slowly start seeing what was damaged:(!!!!
