southdave
- 6
- 38
- ripley, oh/TDY Lordstown,Oh
FYI-there is a by-pass fix, by installing a push button monentery switch and AC-60g glow plugs.
OK, on your other thread I specifically told you that you MUST clean all the connectors free of oil because IT WILL cause enough resistance for them not to work properly...I added photos.
But anyhow, dug into the truck today, removed the GP card, cleaned it up, and removed the GP themselves. The card looks fine with now burnt spots on it, and the glow plugs look ok.. The connectors to the GP were a little loose and i will replace them (what color connect would be best? blue? red?) and i was thinking of soldering the connectors and puting a insulated sheath over the connection point, would that be ok? or to much heat?
Here is what I found:
The glow plugs were a little oily, which i found out by a GM Tech thats ok if they aren't working properly. Which blue wire do you tap to the push button switch for manual operation, dark blue or light blue?
http://www.steelsoldiers.com/cucv/56231-when-cold-wont-start-w-o-spray-even-then.html#post649994what ralbelt said.
I'll add you probably have an air leak in the fuel filter backing plate. You can get the whole assembly shipped to you for about $80 on Ebay. Bolts right up. Bleed the fuel system. Should solve all sorts of fuel delivery problems.
that and the glow plugs systems.
on the glow plug systems - has at any time in it's life has your 6.2L valve covers leaked? EVER? Mine seem to leak at the front, just a little. But over time, the oil will weep down into the connector and onto the top of the plug. Most folks drop the money on a new set of plugs and MANY comment on how the plugs they removed looked ok.
If you have had an oil leak, one at a time pull the electrical connector off and clean the connector. I use Qtips to get into all the nooks and crannies. Once it's clean, wipe down the top of the glow plug. Repeat this seven more times.
Replace the fuel filter backing plate.
I'll bet money it fires right up.
Keep us informed.
The Tech Manual has a step by step procedure to test the Glow Plug system. Look it up, print it out and see what the issue is.Right, that what I was thinking of doing, but the GP Controller card looks fine, the GP look fine (tested them all have .08-.09ohms)... I'm going to look at the resistor bank in the back of the engine now and i'll take a photo of that. If everything looks good, and working properly, then I wont need the momentary switch...
But if i was to do the momentary switch, which wire is the GP relay? Dark blue or light blue?
