oddshot
- 116
- 43
- Jasper, Georgia
I wonder if the Deuce FUEL systems generate enough pressure to power one. That would be interesting for folks running WMO/WVO. Time to start doing some research.
How did you fabricate a mount, and a drain-back ?Ok guys I have been researching bypass engine oil centrifuges for the last few months.I wanted to do a write up on it to remove some of the mystery behind a simple part and hopefully save you guys some money. I finally purchased one from PAbiodiesel supply. I purchased the 65GPH model I just could not justifiably spend almost a 1000 dollars on the Spinner II. The only difference between the two is the drain back is air forced on the Spinner II and PABs is gravity drain back and less parts. I will be using the oil sample port to feed the centrifuge and either the valve cover or breather tube or turbo drain as possible drainback locations.This install should cost 200$ or less You will need to fab a drain back and a mount possibly .Heres a link to my first youtube video and first series. http://www.youtube.com/watch?v=dkJsqqZMHNw
Sorry to hear that, hope you're doing much better now.Ok I wanted to update the install status for all of you. I have the centrifuge installed and working I have a video also.I am sorry its taken awhile with the weather and waiting also on PAB before putting it public,on a side note I was in ICU for a few days almost died from diabetes I had been sick for along time and didnt know I had it. I will put the video public ASAP if it will help the site.
