SeeNebraska
- 23
- 8
- Nebraska
can someone walk me through how i should drive an flu419? i looked at one today but the seller is the wife of the guy who used to use it. She knows nothing about it or how to use it and her husband isn't available to help.
i got it started, cycled the loader, checked out the backhoe, got it to latch in and stow away. then when it came time to drive it, i started having issues.
what is the basic theory of operation for the different levers. there is the I/II/R selector as well as the 1/2/3/4 selector with the high/low switch mounted on the rod. are you expected to use the high/low switch when working up to convoy speed?
The clutch is leaking fluid somewhere so the pedal doesn't feel great and requires a lot of pumping to build up. If the clutch isn't disengaging, will it give me trouble changing gears and speed ranges?
my trial driving today was a big failure but i'm thinking a lot of it was my fault.
the front loader was inconsistent in its movements, sometimes it wouldn't actually move up, other times it would but sounded rough. Would that be from air in the system? the backhoe cylinders leak pretty bad so it was very low on fluid when i first started looking it over.
thanks
thanks
