- 290
- 20
- 18
- Odessa/Texas
I see the hole in the screw-head for the tie-wire.Can this be causing any issues, this is a far as the thumb screw will go down. The adjustment screw is preventing it from going any further, it had lock-wire on it when i received it was cut and just hanging off of screw. So I removed it that piece of lock-wire that was just hanging.
Nice find!
True for conventional generators like the 002, 802, etc but the 831 is an inverter generator.Hz will be the most accurate.
Thats true if you are taking the frequency of the power BUT if you look in the TM you'll see the procedure for setting up the governor and it shows you how to take the frequency of the PMA which is mechanically tied to the engine.True for conventional generators like the 002, 802, etc but the 831 is an inverter generator.
Frequency is maintained by the 831's inverter.
Ah... Didn't know about that tidbit in the TM.... if you look in the TM you'll see the procedure for setting up the governor and it shows you how to take the frequency of the PMA which is mechanically tied to the engine.
