auctionaddict
- 15
- 18
- blue ridge, ga
I have one ordered.Have you changed the fuel filter?
I think i'm gonna cry !!
New KDS smart start with controller, Ground harness, new glow plugs and new batteries.. It still wont start !!
I guess IP pump maybe ?
I have fuel squirting out of filter housing exit when I turn it over, but no fuel if I loosen the hard line at the head and spin it over..
This is an 86 hmmwv, Do I have the wrong pump and lines ??sorry, i see do this..and as Ted said....
you out pump is bad...or clogged. Yank it.....also take your injectors and pet them pop tested...or get new ones if you are going to do a new pump. The pump model is on the left side of the pump...use a flash light.
Have not, I plan on doing so.. Its full of red off-road.Did you replace the fuel in the tank with fresh?
The pump will work...its possible the motor was replaced....you really need to know what injecotors you have....for that pump its the short bodied injector. But i have had pumps do what your is doing. Send it out or post in the wanted section over on g503.
Not sure what you mean....injector tool? All that required to remove is a deep dish 30mm socket.
