- 419
- 0
- 0
- Joseph, OR
I tried my first tank of WMO blend today and engine shut down after three blocks. I filtered the WMO through 1 micron filter and water separator. Good looking batch of lube oil that came out of a CAT engine I manage. I mixed 20 gallons of WMO with 30 gallons of straight diesel. Engine has been running good with no problems on diesel. The WMO has lived in a 50 degree F. garage as has the deuce. The weather outside was about 33 degrees F. so should not have been a problem, right? Not too cold for a 40% WMO to 60% diesel mix. It was not even outside long enough to get cold. The engine just slowed down and stopped. It would crank but not fire. I got it towed back to the garage and after 4 hours in 50 degrees F. it would still not fire. I checked and had good fuel supply (black but thin) at the top bleeder on the secondary fuel filters. I changed the primary and secondary fuel filters anyhow. Still no fire. Anyone have any ideas?
