Okay! Got the headlights working. Although they have some condensation, they do work.
Lesson learned, I watched a couple videos showing the wiring to the headlights, well, it was wrong for my application. So after checking the voltage on the dimmer switch and nearly placing and order for new lights, I decided to test each light using a battery. Should have started there but got it in my head that I had to wire the Llghts (adapter) like shown on the video.
Also checked my original turn indicator bulb and it works too. Just doesn’t work in the indicator socket on the turn signal. When installed it does not light up and is now causing the turn signals not flash. That will be my next project. Maybe a led bulb will work??
