Nick30605
- 0
- 6
- Atlanta GA
I need to remove the fuel injection pump from my FLU419. Have any of you guys attempted this? If yes, do you have any advice before I get started?
My advice is more of a question: Do you need to, or are you doing it without knowing if you need to?I need to remove the fuel injection pump from my FLU419. Have any of you guys attempted this? If yes, do you have any advice before I get started?
It would be great if you post photos and notes on the removal and installation of the pump, on this thread. I have not had the need to remove a pump, but luck may have it one of mine may go out next week or next monthI need to remove the fuel injection pump from my FLU419. Have any of you guys attempted this? If yes, do you have any advice before I get started?
The driver's side window has this written on it: "Mold in Tank" and "Fuel Pump Inop". I was hoping the guys at Red River Army Depot wrote that initially, then "overhauled" the necessary components to get it running....but that doesn't appear to be the case.My advice is more of a question: Do you need to, or are you doing it without knowing if you need to?
Agreed. The guys at RRAD are given 30 minutes to get a unit started or it is listed as a non runner at auction. The problem may very well be prior to the injector pumpNick, I've done those same things, with the same result, a few times now.
What I haven't done is replace the injector pumps. So far it's been air leaks and dirt that kept the engines from starting, or running right.
I'm not saying that your pump is good, but rather that there's a very good chance that it is. Once you have checked and/or replaced each hose and washer, and made sure that the strainer gasket seals properly, then (if it still won't start) it's time to...check all those things again.
I don't remember if it was a separate thread, in the SEE, HMMH, HME thread, or both, but these issues have been discussed and documented with photos fairly well by now.
Okay, go back and look for "FLU fuel issues", a separate thread. It may be a good start, no pun intended.
I have looked through all those posts previously and spent many hours reading through all the different comments.Nick, I've done those same things, with the same result, a few times now.
Good. Now all you need to do is to spend some quality time checking those fuel lines and connections, again.I have looked through all those posts previously and spent many hours reading through all the different comments.
I haven't cracked open an injector yet. I'll give that a try also. Thanks for the tip!Good. Now all you need to do is to spend some quality time checking those fuel lines and connections, again.
By the way, if hitting the starter button with your right hand, you can spray the ether into the snorkel intake with your left hand. With a little practice you can keep it running fairly consistently that way.
Have you cracked an injector yet to see if any fuel makes it that far? I haven't had to do that, but it could be telling.
It's funny that you bring that up. Currently, I have the snorkel disconnected due to some wiring that I'm repairing from a mouse/rat chewing on it. I was spraying ether directly into the intake. I'll put it all back together and see what happens.There could be another reason for a non-starter. I just remembered unscrewing the wingnut on the air cleaner, for whatever reason, while the engine was running.
That lid practically had to be pried off because of the negative pressure inside. Made me wonder if that is how it's supposed to be, or if there's a restriction in the intake.
If the restriction is high enough, the engine probably wouldn't start.
I opened up an injector (see photo).Good. Now all you need to do is to spend some quality time checking those fuel lines and connections, again.
Open up the bleed valve on the filter housing and pump the primer to see if you get fuel to that point. If you do, you can narrow down the possibilitiesI opened up an injector (see photo).
I pumped the fuel primer several times, but nothing happened. -Should fuel pour out of this area while pumping the fuel primer?
Several times? There's been times when I stopped counting pump strokes at 100. Which inspired me to plumb in an electric pump, and later why I pressurize the tank.I pumped the fuel primer several times, but nothing happened.
-Just tried that. I opened the bleed valve on the fuel filter housing and started pumping. Fuel flowed quickly out of the bleed valve screws.Open up the bleed valve on the filter housing and pump the primer to see if you get fuel to that point. If you do, you can narrow down the possibilities
