@Ford Mechanic
I understand the hydro hose bursting and loosing steering, but I don't get how a mechanical linkage prevents that. I have seen tie rods, drag links, and pitman arms fail and result in loss of steering. I also believe the majority of rear steering failures you see in Monster Jam are from landing on one rear wheel and creating massive pressure on the system causing the rams seals to blow out or a hose to rupture.
@ InfiniteFoamies
I also agree that there should be some way to lock out the system. I had thought this up awhile ago for a truck of mine I was going to build. My thoughts were to use a short hydro cylinder and pin to engage a stationary arm on the axle and another arm on the knuckle. This way the axle would be locked in a straight position but also allowed it to be unlock without having to climb under the truck.
