wbdodgeiv
- 0
- 16
- Roanoke, VA
Does any one know the correct rpm for the in take fuel pump? Mine went TU a few days ago and the engine has gotten hard to start. Took the pump out and nothing happens when you flip the acc switch on. If I rap the can with a screwdriver it runs very slowly making a rattling sound then stops. It also rattles when I shake it, I think I may have lost a brush.
I am considering reusing the pump and replacing the motor with either a sealed motor mounted high in the tank or mounting the motor externally and running a drive shaft through the hole that used to be used for the motor wire to fuse bulkhead.
