fal_shooter
- 0
- 0
- Post Falls, ID
I need a fuel tank sending unit for my 1986 M1008. Does anyone have one they want to sell or can anyone give me a part number? Thanks for your help.
Fuel Sending Unit
I work for Napa, just ask for the sending unit for the "correct side sending unit". When I replaced my unit, I flushed my tank with water. I let it air dry, and put alcohol to flush out the rest of the junk in there. Then cut out the hard connection fuel tube and added rubber tube to the junction to the rest of the connection, works perfectto. Hope this helps.
That black wire goes thru the hole in the frame and gets bolted fast to the inside of the frame rail face. It is the ground for the fuel sending unit. Not sure how that works. I just follow the OEM design and it always works. Electrical is my week link.
It's the exact same sender as posted above. That's why I qouted himWOW. Need a picture of that. Do you have the correct sending unit? Where did you get the sending unit?
