Generator drive pully. Cummins
texas-5-ton
10
Grandview, TX
After I posted earlier Mike, I got to thinking that maybe you could take your generator (or pulley) to you local alternator or generator shop. The one here usually has a mountain of old alternators laying around and maybe they could get you fixed up as well. One more avenue, you might also check with Red River and see if they can get one for you.
hope this helps [thumbzup]
Chad
2,758
Is it the pulley on the gen. or the pulley behind the damper?
TheBuggyman
Fredericksburg, Virginia
Alright, took off the pulley I have and it measures an approximate 5/8" bore with a keyway, overall OD of 3-5/8" and two grooves. Did not find the SP992 number that you listed but on the back of mine are two casting numbers as follows:
LN78128
ORD.108898(or 9)29
Let me know if this will work.
