Halogen Head Lights
1,807
Huh? How much are they? I didn't know they exist but i'm interested. Heck, the standard sealed beams cost enough. I found a great deal a few years back at $10.00 each. I bought 10 of them!
Loose Deuce
South MS.
Well, I found the info in one of those MVPA PIPE LINE magazines. They dont have a web site, but they show a ph# 423-272-0690 and email;westernresource@aol.com its on page 48 of November 2004 issue. I ordered a catalog, but if you find out what the deals is, post it.
You can get anything you want in America, just got to find it,and have the cabbage,right.<img src="emoticons/icon_smile_approve.gif" alt="Approve">
Desert Rat
LD;
Yeah, and hope it hasn't been outsourced overseas............ Jobless "recovery" anyone?<img src="emoticons/icon_smile_angry.gif" alt="Angry"><img src="emoticons/icon_smile_thumbs_dwn.gif" alt="Thumb Down">
Loose Deuce
South MS.
I found out what they want for the Halogens, $110.00 for two. Too rich for me, I can live with the stock type for now. <img src="emoticons/icon_smile_jawdrop.gif" alt="Jawdrop">
This is what they said: H4 bulbs, 24v at 75 watt, requireing no relays. I dont know what H4 bulbs mean unles its the size?<img src="emoticons/icon_smile_blush.gif" alt="Blush">
Gangrene
The H4 bulb is the replaceable halogen bulb. Available at any auto parts store, Wal-Mart, etc. (12V only) The 24v versions will need to be ordered, or should be available from truck parts retailers. You could wire the lights in series and use 12V bulbs as an option. Have you checked the size of the standard Jeep Wrangler headlight? Hella makes a 2 piece (bulb and housing) headlight replacement for them. The 24V H4 bulbs could be sourced seperately. The $110 price tag doesn't sound too bad to me considering that the housings are not consumption items, just replace bulbs ($6 - $15 /pr.) The Jeep headlight replacements I have seen start under that price and go a little above it.
Elwenil
40
Covington, VA
Watch wiring the headlamps in series, if one goes the other should too and then you have nothing. I was working on this problem for my M715. I thought I'd get a set of Halogens in 24V and just resolder the mil wire connectors on, but the only thing my Sylvania catalog lists in a 3 terminal sealed beam is an aircraft landing lamp that is a clear, unfocused lens that would blind the crap out of everyone. Still checking on a few other leads on 24V halogens though. If I find anything that will work I'll post it up.
solar powered
Any 7", preferably the E-Code Hella,Cibie,Marchal etc. housings will fit. The only special part is the 24V H4 bulbs, and I found mine cheap on ebay. I used cheap no-name E-Codes @ $15.00 a pair on my M35 and spent $28.00 for 4 24V Hella H4 bulbs.
Elwenil
40
Covington, VA
Yeah, I've known about the H4 style for a while, but I'm trying to come up with a stock style sealed beam, but in halogen. Should be a lot cheaper too if they're out there.
