wsmayeux
- 0
- 1
- Carbonado, Wa
Alternator woes
Alright so,
Last week i brought home a 1984 m923a from gl in Tacoma. On the way home, i noticed that the volt gage was reading in the yellow. Huh... A little further down the road, the fuel and water gages started jumping like mad...... Now i new the batts were prob junk as i had to have it jump started there. So, i swung into wally world to pick up some batteries on the way home. i removed the old, had them tested. Two dead, Two weak. replaced batteries and started......Fires right up and .......gage in the yellow. i begin my inspection of wiring and find that the batt wire on the alt is fried at the connection. Well at the end of the wire because it was BURNED OFF. it appears that the wire shorted to the cover at some time. Looked to be awhile ago. So no prob i thought ill just fix the wire....got home fixed the wire and no go. still not charging. cjhecked voltage at terminal read batt voltage 23 volts. So with a little investigation i found that the voltage regulator was fried also. Ordered a regulator....waited impatiently for the ups man. Today the regulator arrived. I quickly installed it, reinstalled the alt and.........no go again!!!!!!! Dang. I then removed the alt again ang began further inspection. what i found was that the rotor windings are burn up also. If you look in the alt with a flashlight you can see them.... toast. dang.... Soooo does anybody know how much an alt rebuild costs????? Anyone in the Tacoma/washington area know of any good rebuilders? I alread found a 24 volt delco 1 wire for around 100 bills, but i just got this brand new regulator and id like to be able to utilize it one day, so i dont know if i wanna go the delco route. at least if i replace it with stock ill have a spare part..... please, any help would be great...i just wanna get out and drive this thing........ A couple of years ago i had a m35a2 when i lived in va. But alas we had to part when i moved to washington, so im really itchin to get this baby on the road and start playin. Its like therapy i think....good for the soul.
please help this desperate mv'er
Bill
Alright so,
Bill
