- 34
- 5
- 8
- Atkins AR.
What is the wiring diagram numbers for the gauges
Temp?
Fuel?
Batt?
oil pressure?
high beam?
dash lights?
Temp?
Fuel?
Batt?
oil pressure?
high beam?
dash lights?
What are the wire numbers that plug into each gauge?Not sure what you are asking for, the wire numbers are on the applicable schematic, there is not a schematic for the instruments only, just complete vehicle schematics.
Here is a schematic that the numbers are clear on, as far as the instruments all HMMWVs are about the same, kind of a PITA but the best one I have is too large to post
You are now realizing that there are technical manual on this bulletin board that are free. Mogman is strongly implying that you need to go through the technical manuals on your own to search out the circuitsWhat are the wire numbers that plug into each gauge?
Temp?
Volts/BATT?
Fuel?
oil pressure?
WOWYou are now realizing that there are technical manual on this bulletin board that are free and Mogman is strongly implying that you need to go through the technical manuals on your own to search out the circuits
US gobment rote it down for ya’ wit letters an’ pitchers and ebythin’WOW
Lot of good helpers on this site!
Thought maybe someone already had it written down some where
GUESS I WAS WRONG!!
That is exactly what was in the attachment I posted for him!All of this is located in the back of the TM 9 2320 280-20-3 manual. If you haven't already downloaded them you should!
is the ranger tab for show? Or did you earn it?THANKS FOR YOUR TIME
Because 27x27=729-27-27-27-27-27-27=567...DUH !!!All of this is located in the back of the TM 9 2320 280-20-3 manual. If you haven't already downloaded them you should!
Now the REAL QUESTION here is why is the +24V power to the voltmater labeled 567A when it's simply another lead coming off of the 27 line?
