hmmwv tachometer installation
Retiredwarhorses
4,181
Brentwood, Calif
Because the military tach is a 3500 rpm gauge which is more responsive to a low-rpm diesel engine. I am preparing to install a new HMMWV 3500 rpm tach in my M1028 in a custom-built cluster and have the HMMWV sending unit which mounts on the oil pump drive, however I have not tested this connection and do not know that the signal from the sending unit will be correct. I am also interested in knowing the outcome of this thread. Here is a photo of my sending unit and cluster -
View attachment 820184 View attachment 820185
1st, The tach you have pictured is simple, I have installed many and sell them, the instructions for install are available via search in this forum.
2nd, the OP is not installing this into a hmmwv from what I gathered, it a 12v civilian truck.
so instead of reinventing the wheel, just buy a civiy Tach already available The civilian H1’s all have Tachs.
The Tach drive you refer too in your pic is for the STE/ICE application, it was not meant to produce the correct signal for
TCM applications but does for this Tachometer only, the cannon plug version of late style Tach gets its signal from the
generato.
Sharecropper
987
Paris KY
generato.
Warhorse - Thanks for your reply. I apologize, the thread is so long and old that did not read all the way back and see that the OP intended to install the tach in a civilian truck. Regarding my tach, do I understand you correctly that the sender that I have will indeed provide the correct signal for my tach? If not, is there a specific sender available that will provide the correct signal? Thanks again for your help.
Retiredwarhorses
4,181
Brentwood, Calif
The statement about the OP’s application vehicle is the post above my reply....
But yes, if you have the 4 screw Tach, that sending unit provides the correct signal.
Sharecropper
987
Paris KY
Thank you soooo much! Yes I have the 4-screw tach. Question - would you happen to have the male end of the cannon plug so I can fabricate the harness from the sender to the tach? Here's a couple photos of the female end at the sender -
Female-side of plug on HMMWV tach signal sender - 2.JPG Female-side of plug on HMMWV tach signal sender.JPG
Retiredwarhorses
4,181
Brentwood, Calif
View attachment 820187 View attachment 820188
just cut the plug off and use new connectors, makes no difference which wires you use for signal, works
either way. Or use Posi-taps.
Thumper580
210
Virginia
Can someone tell me the outside diameter of the 3500rpm M998 tachometer body, not the ring that goes around the face. Need the body OD for fitting into a housing. Thanks, guys.
Sharecropper
987
Paris KY
The tach body will pass through a 3-3/8" hole. There will need to be a small notch at 6:00 for an indexing ridge on the tach to fit into. Hope this helps.
