Good morning all,
I have finally acquired my first genset. She is a trailer mounted 005AAS, with the acoustic supression kit. 483 hours on the clock
I am starting to work out the bugs and “pretty her up”, so I will be looking for parts.
firstly, what is this goo? (See picture
I would like to convert the oil filter and fuel filter housings to accept a spin on style. I have found what I need for the fuel side, but not oil. Any suggestions?
The ammeter is showing as not charging, verified with a DMM. I will need to find an alternator if one of the fuses check out, or source a rebuild
Governor/ throttle control cable will need replaced
The Fault indicator panel is completely inop, so that will require some digging to diag and for whatever reason the stop-run-start switch becomes inop for a short time after a ride down the Road. Interesting bugs
The M200A1 trailer she sits on is pretty rough in my opinion, so I’d like to source an alternative single wheel trailer if anyone has suggestions.
I didn’t get a screaming deal on it, but I believe it was fair. What do y’all think?
