OD Green
- 13
- 3
- Massachusetts
Hello all,
I'm looking at replacing the problematic pneumatic powered hydraulic pump on my M1078 with an electric powered hydraulic pump. There are reasonably priced pump/tank combos out there- It would seem a single port unit with gravity return would bolt right in, abandon the present air line and use the tethered control in conjunction with the present hydraulic manifold. The present system uses only 3 quarts of ATF but has space for a couple of gallons in the tank- must be room for excessive return under some condition. The pump I'm looking at is something like this, "Mophorn 12 Quart Single Acting Hydraulic Pump 12V Hydraulic Power Unit with Steel Reservoir for Dump Trailer Truck Car Lift Unit" Has anyone gone electric and if so what did you use for the new pump/tank? Thank you! [h=1][/h]
