JGolden
- 0
- 0
- Lithia, Florida
Hello
I replaced a bad injector cap on my truck a while back and i lined all the ticks up instead of having the injector cap gear (red notch) one off the arrow a little (when the advance unit timing mark is lined up). I also remember turning the engine to line up the marks on the crank shaft damper. It ran slow and had a little more smoke and vibration. Now I'm going back and following the LDS-465-1 trouble shooting manual. Since i read it was a good one to follow.
Timing the fuel injector pump is no problem.
My concerns are:
1) I don't know what engine i have for sure.
I think i see a He... (assuming Hercules). Plate is stamped 4-89 pretty sure this was the year it was overhauled. TD is cast into the engine block.
It looks like my other engines which are 134hp, turbo-charged, non-whistler.
I thought these were LDT-465-(something) but the marks on the Crankshaft says only LDS and LD. the best i can see.
2) There is a deep "V" scored into the Crank shaft damper about 130 degrees from the 3 main timing marks. The rockers feel a little looser around the timing marks than they do at the "V". The V lines up when the first cylinder intake valve just closes.
This might be trivial stuff to figure out but Ive never done this and just need help getting the right mark on the crankshaft damper.
Thanks for Everything.
My concerns are:
