70deuce
- 121
- 43
- Franktown, CO
M35A2-AZ, thanks for the info and the excellent picture of the mod. Were you blowing out the high pressure seal right behind the shaft bearing (gear case side)?
Glad I could help, Yes I was blowing out the seals on the winch side and filling the winch with fluid.M35A2-AZ, thanks for the info and the excellent picture of the mod. Were you blowing out the high pressure seal right behind the shaft bearing (gear case side)?
That is not good!!I had hydraulic/gear oil spewing out of the gear case vent on top of the gear case. That motor had been replaced during rebuild and looked new. Thanks again for the info.
I think the one with the plug on the bottom is a newer Parker motor.Albert, I was finally able to get out to my truck today (rebuilt 2010 A1 version), no plug on the bottom of the motor? Any idea if the plug version is an updated or older version from the non-plug hydro motors? Now I'm wondering what do do about the motor over pressurizing as you've described?
Wow. This should be sticked or something. Why? Because I think it just saved my butt! Lemme 'splain.....FYI, If your new Parker motor has a allen plug in the bottom side of it, you need add a case drain to it. If not you will be replacing it soon. I had my motor repaired two times before they told me it needs a case drain.
