That was the problem started right. Now i don't have voltage 65 volts at l1 -3, adjustment dose not work and hertz won,t go below 61I do have one not sure why , or if it's good
I have another VR mabe swap out?That was the problem started right. Now i don't have voltage 65 volts at l1 -3, adjustment dose not work and hertz won,t go below 61
yesDid you hook my VR's wire back up to K15-1?
Frequency is set by adjusting the Frequency Adjust throttle cable located on the far left as you're facing the control panel. Recessed black knob. unlocking the knob and turning it will adjust the frequency (engine RPM).
frequincy stops at 60
yes it drops to 0 sodoes the hertz ,about 200 voltsWhen you start the generator and hold S1 in START is the correct AC voltage displayed on the generators AC Voltmeter? What voltage does it read?
Once you release S1 back to Prime/Run does the AC voltage displayed on the generators AC Voltmeter drop? What voltage does it read?
Make sure the wire from my VR labeled M7-I is on the correct terminal on the Oil Pressure Gauge.
It should be on the "I" terminal, not the "S" terminal.
[/ THAT DID IT!.. MY OIL GAGE IS OPPOSITE OF THE PICTURE NEEDED A MAGNIFING GLASS TO FIND I TERMINAL
HERTZ HAS LOTS OF AJUSTMENT SO DOES THE VOLTAGE I'M STOKED THANKS FOR YOU PATCIENCE MIKE
Thank you Who has it?TM 9-6115-642-24
Here.... MEP-803 TM'sThank you Who has it?
How many feet did you run it?I run mine out the window in my garage when testing products.
I used Walker 40001 flexible exhaust hose.
Walker 40001 Amazon
How many feet can be run before back pressure is a problem?About 6 feet.
It's just a temporary setup I use in the winter so I don't have to test products out in the snow and ice.
All you guys are amazing. Blows my mind the troubleshooting done thru this forum.Make sure the wire from my VR labeled M7-I is on the correct terminal on the Oil Pressure Gauge.
