jmenende
- 378
- 63
- Puerto Rico
Hey guys. Im looking for a thermostat for my mep 005a. Looking for the robertshaw 330-180 but its not available. Anyone know where to find it or a replacement? Thanks
OVERALL HEIGHT | 3 33/250 INCHES NOMINAL | |
MOUNTING METHOD | FLANGE | |
FLOW CONTROL DEVICE | CHOKE | |
LARGEST OUTSIDE DIAMETER | 2 23/200 NOMINAL MILS AND 2 13/100 NOMINAL CENTIMETERS | |
USAGE DESIGN | CONTROL ENGINE COOLANT TEMP | |
III THERMOSTAT TYPE | ANY ACCEPTABLE | |
OPENING TEMP RATING | 177 DEG FAHRENHEIT MINIMUM AND 182 DEG FAHRENHEIT MAXIMUM | |
OPERATING TEMP RATING | 205 DEG FAHRENHEIT NOMINAL | |
SPRING OPERATED PRESSURE RELIEF | NOT PROVIDED | |
NONDEFINITIVE SPEC/STD DATA | 1 TYPE AND 1C DESIGN | |
FSC APPLICATION DATA | GASOLINE ENGINE,NONAIRCRAFT |
Yep, exact fit at a great price.Did you ever receive this thermostat from BJ's Off Road? Proper fit? Work well? I need one, also!
Super! Thank you very much for your lightening fast reply. It is most appreciated!Yep, exact fit at a great price.
Actually I just submitted my order to oshkosh for the 005a thermostat and gasket. Lets see if I get original or napa. Will report back.Well, I ended-up ordering my thermostat for my MEP-005a from Oshkosh Equipment Sales. I also bought the gaskets and a spare thermostat. I've purchased other parts from them in the past, and shipping times and parts are great. I know I pay a slight premium buying from OES, but they stock origianal, military parts, so I'm okay with that. They listed the original NSN number for the thermostats as in stock. 6620-00-841-1892.
However...Upon arrival of the MEP-005a thermostats, as opposed to being packaged and labled with the NSN number, the thermostats are NAPA Balkamp, 195 degree thermostats. (Rather dissappointed, since I had expected to get the original spec's NSN number parts).
So, my concern is the original thermostats specs as listed in this thread above are opening between 177 and 182 degrees, and operating temp is 205 degrees.
These NAPA thermostats are labeled on the box as 195 degree.
Anyone see any problem using these 195 degree thermostats, versus the 177-182 opening/205 degree operating thermostats? I'm thinking I will be okay, but here in the Texas summers, absolute correct cooling is important.
I just kind of bugs me when I expect to get NSN, original labeled parts, yet a part I could have purchased at NAPA (very likely at a lower cost) arrives.
Thanks!
Looking forward to your report!Actually I just submitted my order to oshkosh for the 005a thermostat and gasket. Lets see if I get original or napa. Will report back.
