Maddogg2.0
- 0
- 0
- Riverisde, Ca
Is that repaired with an adjustment, or will I need to pull it apart?
I read in an Army or USMC publication recently that the wiring for the convenience outlets on the MEP-802a was underrated at 10 amps instead of 15 and causing fires. The solution was to immediately disconnect it until all required wiring could be replaced.I would also check the valve adjustment and engine timing as soon as I could. TM's explain the procedures. Not as hard as it first sounds when you read it. You asked about the courtesy outlet being disconnected-I had two 002's with the courtesy outlet also disconnected. Never found out why.
You are on the right path.
David
Maybe we should make this problem/repair a sticky? I've had my 003 for a few years now and never knew this and my recept is connected, but no idea yet if it's supplied with #14 or #12.I read in an Army or USMC publication recently that the wiring for the convenience outlets on the MEP-802a was underrated at 10 amps instead of 15 and causing fires. The solution was to immediately disconnect it until all required wiring could be replaced.
I noticed on my 802 immediately that the wiring looked way undersized for the power rating of the outlet and GFCI.My GFCI was hosed, so I just bypassed it and replaced the outlet directly with a household GFCI outlet.
I'd bet the 002's and 003's had the same issue, or some units also disconnected those after a fire or two.
If you're reconnecting them, check the wiring and make sure it's rated right. I know household ratings are AWG-14 for 15 amp circuits, AWG-12 for 20 amp circuits, etc. Not sure if it's the same for the generator, but most of us are going to end up getting wire at Home Depot, so might as well go with that...
I'd be happy to link the documents I read if I could find them. I have a windows phone, and it's easily the worst browser I've ever used, I can't look in the history, and I somehow replaced the tab with something else.Maybe we should make this problem/repair a sticky? I've had my 003 for a few years now and never knew this and my recept is connected, but no idea yet if it's supplied with #14 or #12.
