MyAngry85
- 0
- 0
- Chicago/ Illinois
It's installed correctly. I also had this problem before removing the cover initially. The linkage looks fine and seems to operate smoothly on a side note.
If it runs with the cover off, then that's as far as I can offer without you springing me a ticket to Chicago.It's installed correctly. I also had this problem before removing the cover initially. The linkage looks fine and seems to operate smoothly on a side note.
Good luck, sorry I couldn't be of more help.Ha. Thanks for all the good info. I'll keep plugging away and post my results.
We had a discussion about that once and I think I recall the answer was no.Anyone ever see a manual fuel cut off? I heard tractors with the DB2 had a choke style cut off, but haven't seen anything.
even under the truck back to the tank, maybe a kink or a slug in the line ? It going to be somthing lame it always is just over looking the obvious..I've jumped it and it was a no go. I've pulled the return fitting and same also made sure the return was clear. And I'll take whatever ideas you guys have, really appreciate it.
