Erik Jenkinson
- 8
- 18
- Metairie, LA
The rear seal at my slip yoke is leaking. So is the seal between the main and rear housings. I just need a proper part # for the rear output seal, and I need to know if the rear housing can just simply be un bolted. I believe the rear housing appears to just be sealed with regular rtv. Can I just remove the rear housing after having removed the slip yoke, clean, and re seal with rtv?
