HummerinTX
- 0
- 1
- Denton, TX
It says FL753 on the box. So which bolts do I remove from the plate thats on the truck? All of them on the inside? It looks like some of them go all the way through to the block.That bolted adapter comes off. And the adapter you have goes in its place
What adapter number did you get?
Awesome man! I really appreciate that!Ok, Found some # Baldwin OB-1368 or Hasting KF-26
What website is that from? I've Google it and can't find that for sale? ThanksYea that one you have is for gen set and older units it has a different oil pump setup why i mentioned the adapte4
Order Baldwin ob1368
I also used the Baldwin part simp listed. I didn't see it commented on but there are two small gaskets in the kit. One is thinner than the other. After trial fitting it with the thin gasket, I decided to use the thicker one when I installed mine. I have seen people suggest using the thin one but it didn't look right to me.Products - GFC Performance
Your Source for Wholesale Donaldson, Baldwin, Fleetguard, Mann+Hummel, Racor, Parker -Process, Finite, Hydraulics- GFC, PecoFacet and moreusa.petroil.net
Hi so which one is the correct gasket to use on the NHC250? thicker or thinner? ThanksI also used the Baldwin part simp listed. I didn't see it commented on but there are two small gaskets in the kit. One is thinner than the other. After trial fitting it with the thin gasket, I decided to use the thicker one when I installed mine. I have seen people suggest using the thin one but it didn't look right to me.
which of the smaller gaskets do you use on the NHC250? the thicker one or the thinner one? thanksWhat website is that from? I've Google it and can't find that for sale? Thanks
I went with the thin one. If in question you could call Baldwin.Hi so which one is the correct gasket to use on the NHC250? thicker or thinner? Thanks
I called baldwin, tech guy randy said use the thinner one on horizontal mount NHC motors. ThanksI went with the thin one. If in question you could call Baldwin.
