Mike_Kendall
- 0
- 0
- Columbia, SC
Hello all, Many years ago when I was stationed in the Philippines I had my 72 Bronco with aftermarket high compression pistons in it. I experimented with my own fuel additives using a little imagination and practically no exeperience and knowledge. I tried adding 8 percent tech grade alcohol and succeeded in clogging alot of fuel filters. I then got a cooking propane tank and strapped it to my rollbar. Ran that hose used for soda machines to the vacuum inlet of my Holley double pumper carb, turned up the idle way high to about 1700 RPM. Every morning when I started it up I'd reach back and crack the propane until my tach read a steady drop in RPM down to 750 RPM. Wow, did the knocking from poor fuel immediately go away. I loved it.
I just discovered that ATS markets propane injection kits and was really surprised at the horsepower and fuel economy increase they claim. Website claims that the diesel normally only burns 75 percent of the fuel and there is a major increase in the amount burned. And, in the testimonials someone talks about using cooking propane tanks just like I did years ago. This is a more sophisticated system of course. Has anyone done this on CUCV's or other military diesels? I wonder how the longevity of the engine is affected? It seems to be a different set-up for amount metered if you run a turbo. I'm going to call ATS first thing next week but wanted to ask the guru's on steel soldiers for comments. I've heard good things about the ATS turbos and will ask them about these as well. I'm worried about putting a turbo on my 6.2L because of the weaker lower end of the engine. Maybe just a propane injection without turbo will be a better option. Thanks in advance to all, Mike
