digitaldust
- 2
- 18
- Twp Flint ,Mi ,
does anyone know about rebuilding a pressure plate on the deuce ?
I have one broken finger holder at the pin hold end.
also looking for a clutch disc.
does anyone know how deep the clutch pad should be ? i only have 7K Miles on this truck with a 09 Re-depot rebuild on motor and trans .
Also , what is the difference 3 finger plate or 4 finger plate ?
FYI should you be reading this in a search down the road
Symptoms: Truck had grinding gear noise in 1 , R and did not want to sync going into 2 ,3 ,4 ,5 wile running
with truck not running trans shifted great.
Yes the clutch did move back and forth in the inspection window and adjusting the clutch play did not help.
hope this helps someone in the future.
Best of luck.
Best of luck.
