I just installed a rebuilt IP and can't get the injector line's to bleed.
I've got fuel to the back of the IP (electric fuel pump ) and I see fuel in the return line when I unhook it from the IP but can't get any out to the line's. I have all eight lines loose at the injectors so I can bleed them.
I haven't put the intake back on yet so I could check for leeks. I don't see that it should be a issue. I can crank the engine over but no fuel.
The IP was rebuilt by a local co that's all they do is IP's got to think they know how.
I' ve read several threads on IP's that don't work
I checked the volts on the pink and green wire it's good
Don't want to take the top off yet to check return ball and cylinders but I can hear them working when I hook up the wire.
and yes I read the tm-34
ANY help ?
ANY help ?
