skidder
- 8
- 18
- Winsted,conn
Gentlemen, I salute you, for taking the time an energy an patience to do this for all to benifit from ! THIS, is what its all about !! THE Steel Sodlers Family !!
We put the truck in 5th, high transfer and moved the entire truck.
Send you to school with an apple and you eat the teacher.
5th gear and the transfer in netrual. Pry the jackshaft around with a small bar.
Transfer case in neutral, transmission in 5th and use a pry bar to turn the driveshaft between the transmission and transfer case while your assistant looks for alignment of the red tooth with the indicator mark.Im about to star the process of changing out my HH. When you guys had to spin the motor over, to line everything up, did you just blip the starter?
Sir, Thanks for the response. In the next sentence I said you could snake a wrench through a U Joint, I should have clarified that I'd have the transfer in neutral and snake the wrench through the jack shaft. Nice to see you still on here Floridianson.[/QUOTE]Send you to school with an apple and you eat the teacher.
"AMBAC" is AMBAC International, curiously not the first link that Google produces when searching for AMBAC, but the second or third result. (Guess they didn't pay for the right consultant to get them first place.) Anyway, the link is www.ambac.net... in your post you mention AMBAC, who is that? How do I reach them?...
