OK, just finished the same job. Rather than do my own thread, I'm gonna add some notes to this one. First off the TM's are a royal PIA.
This TM has all the info but it's scattered about.
http://www.steelsoldiers.com/showth...eries-Trucks&p=1451111&viewfull=1#post1451111
Basically...The upper steering arm studs are 150-170 ft/lbs which felt like alot to me for the size of the stud. I would stay to the 150 side of that.
The 9 spindle studs are 130 ft/lbs. The spec is not under any of the knuckle repair pages. Found it under the Brake Spider repair.
page 0427-1 Front Brake spider and actuator repairfrom the TM I posted above.
The wheel bearing nuts commonly referred to as the spindle nuts are found on page 0479-1 Front Hub Maint.
Finding this info took me awhile so I hope it helps someone else in the future. My suggestion is to install the boot clamp on the boot then put the boot on the axle BEFORE you put the knuckle back on and leave it loose enough to clock it once the knuckle is on. Then once the knuckle is back on you can clock it and then turn knuckle to the right and tighten the boot clamp.Much easier this way. Then I would do the 12(?) screws for it before you put the steering arm back on.
The job was time consuming but pretty easy IMHO. Hardest part was getting the axle tube seal out and once I made the proper tool for my slap hammer it popped right out. You will not get it out with a lady foot. Make sure you catch the back of the seal only as the axle tube has a lip inside.
