Well, I have had the deuce for little over a year now. Very enjoyable. One issue is that my front lugs and hub bolts keep coming loose. It has got to the point I check them with a tool ALMOST everytime I come out of the backcountry. I got the truck with one broken hub bolt. I took it on a short 2-3 mile ride while flushing differentials with diesel fuel. Something did not feel right at all so I drove last 1/2 mile home on shoulder at 20. Prior to heading out I already had one sheared off lug from what I thought was off-road collision on hub. Truck has been sitting since and I thought a little 3 mile roundtrip would be no problem... it barely was no problem. When I got home I had 2 more that has sheared off. I haver ordered 6 new LH and 6 new RH. The truck was worked hard before I bought it from the mine.
I fully serviced the truck when I bought it. Brakes, axles, the whole shebang....
Could overtorque lugs cause them to not tighten correctly? I have had zero issues with the rear.
aftermarket wheels, 395 tires, lockers in front axle/rear axles, hydraulic steering are the variables...
