Source for frame bolts?
MGKMartin
23
Portland, OR
Anyone have a source for the 16Mx1.5 frame bolts and lock nuts? I can find the 2mm course thread bolts, but having a difficult time finding the fine thread bolts and nuts from a US supplier.
MGKMartin
23
Portland, OR
Converting a M1088A1 into a M1083A1P2. The bolts to attach the winch, hydraulic tank, subframe, etc are all 16mm x 1.5mm flange/frame bolts. Most are 45mm long, but there are a few that are 35mm.
Suprman
696
Stratford/Connecticut
Some trucks are huck bolted together some are just nuts and bolts. No reason for the difference that I know of. I have used bolts but I don't advise using them unless absolutely necessary.
Will
MGKMartin
23
Portland, OR
All three of mine use the 16mm x 1.5 mm flange bolts. They use the flange nuts for anything intended to be removable like the winch and a longer lock nut (looks like a huck nut, but designed to be put on with a standard impact wrench) for parts that aren't intended to be removed.
