sweet, sounds like the decomp lever you have ins in the same place mine is....i was guessing that it was a decomp but wasn't 100% sure yet.I'll take some more pictures of the motors. All of the engines I was talking about have the decompression lever. The cummins in the 1964 road tractor we have at the museum also has a decompression lever.
About 10yrs ago, the red locomotive that has the same engines (the red one in the video) wouldn't start without pulling it out, letting it spin up to speed, then letting it in. Batteries were too weak to do it with compression on the engine. It was something else having your hand in there, mere inches from the spinning fan of doom.
Well, I did figure out it is a'45 ECT tractor, the data plates were in the glove box, took a bit of work to get it opened (i'll get a picture of them posted in the morning). I have both side panels, just had them off on both sides to access the starter and pump on the cummins a little easyer. The correct wheels are still with the guy I got the truck from, not sure if he'll let them go with the truck or charge me extra for them, they were moved away from the truck when I picked it up so He may be keeping them....will find out when i go back to have him sign the title paperwork.I would look for air leaks in between the ip and the tank. Cracked lines and hoses. It should not need a boost pump. Have you figured out much else about your truck? The front rim is the correct WWII rim, but I can't tell about the rears. The rears (duals originally) should be the same rim as the front. Your truck appears to he the cargo version wheelbase, but those never had the front winch, except for the ECT tractor. I wonder if that is what you have. The ECT's came out in 1945 and all had the 14.00-20 big rubber. Are you missing the passenger side hood lower panel? I may have an extra one. Also, there should be some screen in the oval hood openings, I sourced that from Mc Master if you need the p/n.
Many say so....its been brought up a couple times now.....my truck is the White DevilIsn't 666 the mark of the DEVIL?
