XanRa
- 5
- 18
- Cincinnati, Ohio
im angry now.....
im already looking at m916s on gl lol
Yes you are correct about the speed rating. The 55 MPH rating is at the maximum load capacity though.....I'm not even close to half that weight and we are obviously not talking sustained speed.I'm sure you realize those tires are not speed rated for 80 mph. But sweet none the less. So with the XZL's on it, just how high is that 5th wheel plate??
Well, I had to grind a bevel around the whole outer edge of the inner lip on the front brake drums and grind a small flat as a relieve for the valve stem to make the HEMMT wheels fit. They installed without modifications on the rears but the studs are not quite long enough to stick all the way through the lug nuts. I will have to fix that...i didnt think 16x20s would fit a m916 i like that idea....
Ya'll dont make any mistake here. Soni's USMC M916 ain't nothin' like the usual Army M916 which is a 55 mph, goofy shifting, hard ridin' hauler . . .I have been watching the 916s on GL for a while now . . .
M920;719733 the studs are not quite long enough to stick all the way through the lug nuts. Soni[/QUOTE said:My threads just reach the top of the nut but do not protrude past.
Are you shure you are seated up.
Also I think you might find we only have lockers in the forward tandem.
Nice truck have fun
Jeff,does the allison have a taller overdrive?
Jeff
Thats the way mine are, they just reach the top of the nut....barely....maybe they are ok.My threads just reach the top of the nut but do not protrude past.
Nice truck have fun
She came from the USMC Logistic Base in Barstow CA.Great looking truck! Where did she come from? What kind of trailer are you gonna pull?
Can you take pictures of that?Well, I had to grind a bevel around the whole outer edge of the inner lip on the front brake drums and grind a small flat as a relieve for the valve stem to make the HEMMT wheels fit.
Soni
