- 10,350
- 75
- 48
- Meadows of Dan, Virginia
You probably used a "Megger", pretty expensive piece of equipment for a normal mortal....
And you also don't want to let your coworkers near it when it is signed out - we had a new mechanic in the maintenance shop try to demonstrate his toughness by shocking himself with it and...you guessed it he dropped it in the process. Talk about some unpleasant conversations in the Manager's office!Had to get a cert to use that meter . Nick name was biddle /bond meter. A t tool crib had to leave brass tool check with ss# on to make sure it got back to tool crib.
No the 809s have them along with all the 900s, you can use a 900 PCB on a 809 series but you CANNOT use a 809 PCB on a 900Is this box unique to the 8.3 powered 900 series trucks? It seems as if the newer trucks have the more complicated PCB.
