wsucougarx
- 65
- 48
- Washington State
Turbo Rebuild 3LJ-319 (Whistler) Step by step
WARNING! LOTS OF PICS!!!
I'm in the process of restoring my 1968 JK M35A2. After having tackled the exterior, cab, and PMCS of the engine bay, it was time to move to something that has been on the project list. Over the past 3-4 years I have owned and operated 6 deuces. Coincidentally none of them came equipped with a 3LJ-319. Every one of them had a non-whistler. Though the whistle may get annoying after awhile, I would like to have that option in my inventory
At our last PNW mini-rally, I managed to find myself a nice looking 3LJ-319 (AKA the Whistler Turbo or simply as the "C" turbo). I paid $100 for this clean and free-spinning turbo (compared to $200-$300) on the internet. There was barely any free play in the shaft whatsoever. My '68 has only 5k miles since it's rebuild in 1990 at Tooele Army Depot. Rather than trusting the seals on this turbo, I didn't want to take any chances on a runaway. So I decided it was time to rebuild this turbo. This was more or less for peace of mind.
Presently I am awaiting the rebuild kit. I know I know...where did I get it etc etc etc. You guys are going to have to wait!!! The last thing I want to do is cause everyone to go out and buy a kit that may not fit. Let me get the kit and install it first. OK?
The first order of business was to break the turbo down to make sure the internals were still good to go. You need to pay close attention to the turbine wheel, compressor wheel, and shaft before among other things before going forth with this rebuild. If there is anykind of rubbing of the wheels with it's respective housing, forget it! The wheels are balanced at the factory. Any rubbing of the wheels will throw everything out of balance causing your turbo to self-destruct and empty your pocket book needlessly. Also, you need to make sure your shaft is not shot as you will have freeplay in your turbo causing premature wear.
When breaking the turbo down, take your time and be careful! Here are some pics of the whistler for this project.
This is a work in progress....stay tuned.
Why rebuild a turbo?
New 3LJ-319........$650-$1200
Rebuilt by someone else.......$400-$800
Rebuilt by myself.............$235 total (including the turbo itself) and more importantly one experience point under my belt
FYI Turbo Designations:
Schwitzer 4LE-354 FOR LDS-465-1A
Schwitzer 3LD-305 (old type) & 3LJ-319 (whistler) "C" FOR LDT465's
Schwitzer 3LM-319 (non-whistler) "D" Turbo LDT-465's
Schwitzer 4-456 FOR LDS-465-1
Schwitzer 4LE-456 FOR LDS-465-2
Schwitzer 4D-454C FOR LDS-427-2
Schwitzer 4D-554 FOR MACK ENDT-673
How do you know you have a Whistler Turbo for this rebuild?
Simply look at pic #1 and pic #4 to compare it to yours. The clam shell exhaust housing is a dead give way of the Whistler.
Also the dataplate will have the following information:
Schwitzer
P/N: 11668459
MOD: 3LJ-319
DISCLAIMER:
OK guys, in this write up I try and provide as many pics as possible. I am not a turbo tech and do not claim to be. I hold a Doctorate in Pharmacy (PharmD) not in turbo technology. I do not know the technical terms of the parts so just bear with me. I did some research and hope to pass along some information on what I've learned. That's what we're all about right?
Schwitzer
P/N: 11668459
MOD: 3LJ-319
DISCLAIMER:
