stephenfeldmeier
- 1
- 0
- gillette, Wy
Sometime in the next few months, I’ll be rebuilding another M211 transmission. This transmission had the 1st and 2nd gear planetary carrier slip ring blow out due to someone putting the transmission an a lower gear to slow down the truck. REB was installed when this happened. I got this transmission off an auction vehicle a few ago. I have the parts from this transmission and parts from another transmission in boxes taking up space.
So I want to take all these extra parts and make a complete transmission. In the process of me rebuilding this transmission, would anyone be interested in me taking photos and video through each step. (if it has never been done before)
I will be using the manual TM 9-8025-2 with change one. Since the transmissions are already dissembled, I’ll be going through the inspection section and the reassembly section of the manual. I will (always do) follow the manual to the tee, I will not show short cuts, But since I do not have All the special tools required, I can show ways of doing a step properly (by getting the same end result only by using a different technique). Since this transmission in not going into a vehicle right away, I’ll have time to document every step.
Since I have all the parts available I will point out any special interest anyone of you might have.
One special interest I’ll show by video and photos why to never use Hi reverse.
One area that I wont go into as it was covered over and over plus over and over again is the type of oil to use in the transmission. I’ll be putting 30w non-detergent motor oil in it when I’m done, end of story on the subject of oil to use.
Anyone interested please let me know, also all pictures, CDs and what ever else I do will be free to everyone.
