(Was) on the road, no lights HET
20,466
I found the issue. Two 1435 wires were disconnected. After looking through the TM those were ground wires. Hooked them to a good ground, and surprise surprise, everything works correctly. Bad grounds and no grounds do funny things!
If that truck is occupying too much space in your yard, I would be happy to park it here for you. No Charge!
Glad to hear that you got the wiring fixed up.
Always makes you wonder HOW that happened...
