I want to thank you all that gave me there suggestions. The passenger door has been removed.
To remove the door that I could not open with the handle from either the inside or the out side and what I had to do was:
remove the three nuts/bolts holding the passenger side mirror on,put that aside. from inside kick it outward on the hinged side fwd end of the door. with enough space between the door and the front of the cab I then removed the cotter pin holding the door that prevents the door from opening to much and hit your mirrors.
At this point I had the fwd hinged side of the door out a little. I still could not get the after part of the door with the latch open. I think if this was to happen to any one that does not have keyless entry like I have you would be able to have the door removed with soldier B at this time.
What I had to do next was to use 2 motorcycle tire irons to pry the door fwd and out at the lower corner and to get from the top a thin pry bar to get the door lock pushed inward passed the door lock on the door frame.
Once free and opened with soldier B my Son I rehung the door with the side mirror and then I checked the door locking mechanism,outer door handle all seemed to be good,grassed all moving parts reinstalled.
With that taken care of I tested my keeless entry function that too tested positive. when I installed my access door cover I did not put in the lower screws beneath the door frame so as if this ever happens again i will be able to get access to what I need to inside the door.
