What have you done to your 5 ton this week?
Valor
215
Apple Valley, Ca.
Now that the temps here are cooling down, I changed lube oil and filter. Didn't see any oil drain plug gasket, not in drain pan. I used teflon tape on plug. Hope it doesn't leak. Will do trans and fuel filters next. View attachment 934015
I didn't have a filter wrench big enough for the lube oil filter so I used my belt. Worked great. Belt on oil filter.jpg
topo
258
farmington NM
I started regreasing the wheel bearings on my1967 M52A2 it has been just over 10 years for this wheel and at the time this wheel cylinder was new I took the cylinder apart a cleaned it in soapy water and honed the cylinder on the truck and let it dry then put it back together .
topo
258
farmington NM
I had one more wheel bearing to do on the back and finally made a step to help get in and out of the cab theyIMG_2288.JPGIMG_2293.JPGIMG_2296.JPG are milk crates with a lid made from some screen put inside some window channel from an M211 the step is 13x13 and are bolted to the step
