Is that in addition to the Auxiliary Fuel Pump?I have two one. It has a electric
lift pump. The lift pump is a 2 inch dia. By about 5 inch cylinder.
OK, thanks. Mine is missing some parts and has some wires disconnected. So, I'm going to strip it down a little to lighten it. I should have some spare parts for the classifieds soon, ASK panels, wiring harness, etc.it dont have to have that pump running for the eng to run.. it draws gravity feed off the little tank on top. that pump only fills that "day tank" set up from the bottom tank or another aux. tank source
My meter (Fluke 87) gave me higher Ohm reading than the manual specified. I think I got like 60Ohms on the field winding where the manual called for 27. I haven't made power, yet, but I think the winding is OK.ENGINE RUNS NORMALLY, BUT GENERATOR HAS NO OUTPUT.
Step 1. Check voltage regulator.
Step 2. Check exciter field (stator) for open or shorted windings.
Etc., Etc.
