Good point Chuck! I really didn't think about rocking the long lever back and forth x-times before applying ultimate torque to the point of shear...
But.... do we really see any significant torque in the opposite (reverse) direction, despite the force to overcome the band-brake???
And if so, would it really be an instant full load as to cause that "hammering" condition everytime we shift the PTO into reverse, especially if on the wind-in side the load (under normal working conditions) will increase gradually also???
Certainly it would be difficult to reproduce exact real working conditions during such a quick test...
At least with what we do know already, everybody can easily make- or have access to- "adequate torque-" replacement pins, cheap enough to carry at least half a dozen spares in the glove box, just in case...
Against your statement
"if the holes that the winch shear pin fits through are wallowed out in size, you are never again going to get good service out of a shear pin"..., I say again that the max. torque we can expect from such a pin replaced and immediately put to service at extreme load (typically after the first one has sheared amidst a recovery operation) will mainly depend on material and diameter of the pin, not so on the hole's condition, according to my tests...
To all: drive and winch SAFELY!!
G.
