The 500Watt LED stretched my ability to drive it with simple bench parts - its rating is 6.95Amps @ ~72VDC to output 55,000 lumens. I had to charge a few 56-Farad ultra capacitors I have from a paused car stereo project to run in parallel with the bench supply just to run the two boost supplies for any length of time (boost supplies step from 20-36Volts up to 60-80Volts, bench supply can only go up to 36VDC, and really only outputs 3Amps). I only had about 3 seconds of run-time with the capacitors I have (they need something charging them, so if nothing is available, it only lasts as long as they have enough energy). This experiment left and impression on me like I have rarely had in electronics. At the semiconductor company I work for as a day job (Nvidia), I was thoroughly impressed when they managed to get about 7.1
BILLION transistors into a silicon square of about 1" - large numbers from small things always make me smile.
55,000 lumens is a large number, and having it come from a square that's only 1-7/8" qualifies for impressing me. The one
unfocussed 500Watt LED for three seconds while I was facing the other way (this is a 15'x12' room), was blinding. So how can I translate this into something that means something to you guys - here is a video from Youtube where the guy has 7 x 100Watt HID fixtures on his truck which produces about 82000 lumens (his number, not mine):
Another way of explaining this is if you are familiar with the Spectralab SX-16 "Nightsun" spot light found on many Sheriff helicopters, that unit's bulb produces 75,000 lumens when new. My plan if you recall is to use four total heads on the front of this truck, and two on the back - that's 220,000 lumens up front (half spot, half flood), and 110,000 lumens in the back. The closest thing I can find to 220,000 lumens is a 2500 Watt searchlight that's good for five miles
Even when I get this thing running in low range or "park", I have discovered the
NEED to dim them during the day (especially the ones in spot focus!!). I will also have to use water cooling for the 500Watt LED, and for those who think that LEDs run cool, while that may be true on lower power devices - 500Watts is still 500Watts (1Watt = 3.41btu/hr, or 1700btu/hr each LED). I don't have to worry about ice build-up
