acesneights1
- 21
- 20
- CT
Yeah, hindsight I wish I had bought the bigger Jack back when I bought this one.number one rule> take the top off the trans, it will come out and go in so much easier and you can fill it with oil also. my HF trans jack is the 2000 lb model and it goes up far enough and will roll out from under the truck also, well worth the $200.
put the transfer in neutral and the inter shaft will turn, no need to roll truck.
don't see why you would need to change the adjustment much unless the clutch was really worn out and even then nowhere near an inch. have someone hold the clutch pedal down and see if you can turn inter shaft to make sure it is all working.
I didn't think the Transfer case had Neutral ???
Yeah the adjustment thing is scaring me. Another member asked if I checked the finger hieght as per TM. I didn't realize that. Do the pressure pates normally need adjusting ? I have put many clutches in, including double disk class 8 and aside from the old Macks that used shims I have never had to adjust a pressure plate.
